Auto won't go into "park"
Hi to all you knowledgeable types,
My car has stopped going into "Park" when I push the gear selector forward. It gets as far as Reverse and that's it. I won't be able to fix it myself being very non-mechanical but could anyone advise of the probable scale of the problem. Is it something I shold just live with or a job that needs doing, is it going to be a big, expensive job or a fairly simple one? I realise that nobody can say for certain without having a proper look but some guidance about what I can expect the garage to say would be helpful.
Cheers, Jane
Cheers, Jane
(now sadly gone)
(now sadly gone)
Re: Auto won't go into "park"
Jane - I would think it'd be something simple - like a mechanical link needing freeing up or lubricating, some thing that could be found and cured quite quickly with the car high up on the garage ramps.
65 Peugeot Boxer work van 280k - x 136
Maybe the gearbox lockout solenoid which i think doubles up as the reverse light switch as well, or poss the linkage that runs from the gearshift lever. Thats where i would start.
I presume there has been no attempt whilst reversing to move the lever to "Park" before the car has ceased moving? If so, then burring or damage to the transmission lock would have resulted.
If not, a couple of simple checks you could make would be to unscrew the indicator plate of the selector stick, lift it up and see if there is any foreign body in the space below impeding the movement of the stick.
Also (under the bonnet) if you look directly down from the front corner of the battery you can see the other end of the selector rod/arm on the autobox and just check there is nothing fouling the movement that end.
- Tim Leech
- x 141
I imagine it's probably the shifter mechanism itself, the button you squeeze when you shift into park works on a metal j shaped bar moving up and down inside the shifter. If this comes out of adjustment it will stop you parking. I've had mine apart on the tzi when I converted it from left to rhd and put back together wrong and I couldn't select P. can you choose 1, 2 and 3 ok? If not it's the shifter.
I have a gearshift lever from an auto with the small metal rod should u need it, it came from my 92 tgd that is now manual.
I was planning to take the car in next week to have it sorted whilst I'm on leave but this evening I lost "Reverse" also so I called the RAC. The guy they sent out did all the usual "There's not many of these left on the road, if any." and then told me that he doesn't know much about them. A quick look under the bonnet produced an "It's very rusty" and he then decided it was the cable seized up due to rust. Then he sat inside and forced the selector forward causing it to seize up in some position that wouldn't allow me to turn the ignition. So instead of a car with no reverse I had a car with no power at all. Having had a look at my Haynes manual he decided to remove the surround and try to free up the selector. This was successful to a degree, I still don't have "Park". He then couldn't work out why it wasn't working before and was now and how to put it all back together properly. We agreed to leave the cover off (Tim Leech suggested this also) so that I can at least get to the garage tomorrow. Hope they can fix it as I'm supposed to be driving to Skipton on Friday.
While he was messing about trying to unscrew the selector a man in a white van drove past and took off the RAC van's wing mirror and just drove off as if nothing had happened! Part of me is saying what a prat and part of me is saying "Hahahahaha!"
(now sadly gone)
(now sadly gone)
Hiya Jane. Skipton isn't a million miles away from Lancaster, so if you get stuck let me know.
Cheers Mark. If it isn't fixed properly I doubt we'll be heading for Skipton anyway. Fingers crossed!
(now sadly gone)
(now sadly gone)
- citsncycles
Hope it gets sorted, and bad luck with the RAC - On the odd occasion I've had to call them I must have been lucky as they've either taken my home with no argumen or followed my advice on what's wrong.
- Tim Leech
- x 141
I found the RAC to be better than the AA. remember if youre a CCC member it entitles you to a discount!
- citsncycles
I gather that the RAC are one of the few that actively try to employ a few people who know the old cars in hope that they can send them to the relevant calls where possible
- Tim Leech
- x 141
Its when you get a subcontractor I find you have problems and some ape in a filthy hi-viz jacket shows up with a large selection of hammers....
I've been with the AA for over 22 years now and can't complain. Never had any problems with call-outs. Plus you get 20% off at various retailers when you show your AA card.
I get RAC through my bank along with my mobile phone insurance.
Up till now I have found them to be very knowledgeable and one or two have been quite enthusiastic about my BX.
Anyway, I took it to the garage this morning and it is now working again. The cable was pretty well seized up but they've lubricated it very enthusiastically and it now is much better than its been for a long time. I do need a new cable at some point but at least it's sorted for now.
(now sadly gone)
(now sadly gone)
