Suspension Cylinder
BX4X4X2
Suspension Cylinder
Post by BX4X4X2 »
Hi, does anyone out there want to part with a rear suspension cylinder for a `92 17TD hatchback? (Pretty sure there all much the same apart form estates and 4x4s)
Re: Suspension Cylinder
here is price and part No. from citroen which is still showing as available
95563031 SUSPENSION CYL 151.19 GBP 181.43 GBP 181.43 GBP
if you dont fancy that price give Malcolm Lockwood a call on,
01274 640590
worth a try as he has all kinds of new NOS = new old stock
x 138
Post by rutter123 »
another option is to find a good one from a xantia as i beleive they are the same tho a larger pipe fitting.
Post by RxBX »
rutter123 wrote:another option is to find a good one from a xantia as i believe they are the same tho a larger pipe fitting.
The /\ image from THIS for ref. , I hope it maybe of help ?
