Set of Supension & brake pipes for BX-GT, TRS and others
Frank_O'Phile
Post by Frank_O'Phile »
Almost complete set of new (old stock) original Citroen suspension and brake pipes plus associated sundries for BX-GT, BX-TRS or other BX models.
see ebay: http://www.ebay.co.uk/itm/Almost-Comple ... 233019824?
KevR
Re: Set of Supension & brake pipes for BX-GT, TRS and others
Post by KevR »
Looks expensive 'til you realise the flexi hose at front right is over 200 euros new!
Stinkwheel
Post by Stinkwheel »
I see you are in Northampton, am i likely to know you?
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
x 116
I shan't be bidding because there are no ABS pipes and I have several spare used power steering high pressure flexi hoses in stock somewhere.
Its great that new unused stuff like this still keeps coming out of the woodwork.
I think that flexi is starting to weep on Timex! Luckily I have a good 2nd hand spare but it does make this batch of parts worth watching.
Post by Mothman »
Suspect that the seller will be hanging onto them for a while at that price though.
It's all down to whether anyone out there is desperate for the parts - the starting bid is about the same as the cost of a set of pattern pipes (minus that expensive flexi one), so I don't think it's too far out there.
Post by RxBX »
Mothman wrote:Suspect that the seller will be hanging onto them for a while at that price though.
Your suspicions where negative Andy, as I see that they got Sold with the one bid of £150 + £27 for postage !
