I'm looking for x2 no. 5s.. for my new 16TXS i'm picking up in Derbyshire next week. I will be travelling to Nottingham and back to Holyhead then to Ireland probably Thursday.
Or failing that, anything else really (x4) in the BX vain to give it the presence it requires for a decent road trip!
wheel trims wanted
- maxgreenwood
wheel trims wanted
'90 16TZS (m), White, 86k
Re: wheel trims wanted
I may have a couple will try and check at the weekend.
Hi Kevan,Defender110 wrote:I may have a couple will try and check at the weekend.
I've just sent Max a PM to indeed confirm if its the #5's hes after or the #9's (Which the 'marked up arrow' points to)
As I have TWO brand new #9's C/W the valve cover's available which are in a silver finish (As the St. Tropez used the same style but were sprayed/finished in a 'Gloss White') !
Best to wait for Max to confirm which ones he's after !
- maxgreenwood
Thanks Richard,
Pm'd you
It's 2x #5s I'm after, if that's possible, if not let me know how much you want for the Gti/pilot ones
Cheers!
Pm'd you
Cheers!
Sorry I mis-read and thought you wanted the 9's
I have a set of number 8 and would do a deal for them on asset of steels and a set of number 10 anyone want a deal ???
- Thread Bear
Now that is a useful set of pics. I can sort out my trims now. See what swopsies I have.
T B, heres a set 'without' an annotated arrow, so as not to confuse folk (As what happened /\) if using in conjunction with a Wanted postThread Bear wrote:Now that is a useful set of pics. I can sort out my trims now. See what swopsies I have.
