ignition timing gti 8v
x 138
Post by rutter123 »
how to with a strobe light? where are the tdc marks flywheel or crank pulley, do i need to remove cam belt covers?
Re: ignition timing gti 8v
Umm............Isn't this continuously calculated by the ecu from the tdc sensor and computed by demand? :wink:
x 117
The usual way is to paint a white stripe on the flywheel inside the inspection opening below the thermostat housing. TDC is marked with a line stamped in the flywheel circumference so you need to make your mark at 6deg or whatever it is before this. Then when timing is done make marks on the distributor base and mounting to prevent having to retime again after any removal.
Have you checked that the vacuum advance diaphragm is ok and working ??
x 138
Post by rutter123 »
Way2go wrote:Umm............Isn't this continuously calculated by the ecu from the tdc sensor and computed by demand? :wink:
i dont think the bosch jetronic has a tdc sensor, only the motronic?
x 138
Post by rutter123 »
Jaba wrote:The usual way is to paint a white stripe on the flywheel inside the inspection opening below the thermostat housing. TDC is marked with a line stamped in the flywheel circumference so you need to make your mark at 6deg or whatever it is before this. Then when timing is done make marks on the distributor base and mounting to prevent having to retime again after any removal.
vacuum advance is working ok, but this will need to be disconnected when timing up, right?
Leobx16v
Post by Leobx16v »
It should have a tdc sensor for injection and ignition timing is on the dissy cap iirc, cam and crank timing is done with the belt
1991 Citroen BX 16v - Red
1991 Citroen BX 16v - Silver
1992 Citroen BX 16v - White
Scrapped:
G650PGX 1989 ph.2 red BX 16v
G-VOT 1989 ph.1 White BX 16v
