Alternator problem with BX 19 TDX?
Can anyone advise please? I have just driven from Northampton to London and back (70 miles each way). On the way back in the dark, lights were getting dimmer and when I stopped in Northampton she only started by pushing. Lights almost completely out and would not start again. I don't think the battery would have suddenly packed up (or would it) but is obviously just not charging.
I am not very mechanical and if there is anyone in Northamptonshire who does maintenance please let me know. I am very fond of the old gal and would hate to have to let her go.
Thanks
John
Thanks
John
- citsncycles
Re: Alternator problem with BX 19 TDX?
First obvious question - is the belt driving the alternator OK? Then check the connections on the battery and the alternator, and the engine earth strap (usually bolts somewhere near the battery clamp). After that, I'd go for changing the alternator.
65 Peugeot Boxer work van 280k - x 136
put a multi meter across the battery terminals with the engine running, u should see somewhere above 13.5v then your battery is charging ok. if not i would suspect the alternator. cheap enough on the bay.
Thanks
Will try both tomorrow.
- MULLEY
Sounds like the alternator is shagged. Have you check to make sure the belt hasn't snapped off? The alternatoer also has a connector which should be easy to pull off, check to see if that's corroded, if it is give it a good clean & put it back on & take it off a few times to clean the connections up. Use a hammer by whacking it on the top of the alternator, avoid any plastic parts, they'll go kah-ping & then you'll have a sad face. If none of these work, then its new alternator time, luckily they aren't expensive & are very simple to fit
Thanks a lot
john
john
- Tim Leech
- x 141
if it is the alternator they are not a difficult job to fit to be honest and as mentioned you can get one for sensible money.
- Tim Leech
- x 141
dont be tempted to go to halfords for such things though as they are highway robbery!
I'll second 'whacking' it with a hammer as a temporary fix - trouble is you don't know when it will fail!'
I picked up a genuine Valeo for about 50 quid exchange from one of the decent factors a couple of years ago.
If it's not charging and the charging light's not coming on then I'd suggest it's the brushes/slip rings that are worn out and or just dirty and not making good contact. If the whacking it with a hammer trick works temporarily then you could probably get another five years out of it just by changing the brushes - only costs a couple of quid and easy enough if you've got a fairly hefty soldering iron.
i picked up a bnib o/e pug 406 (slightly heavier duty 5 rib pulley) )alternator off the bay for £30 + p/p, so for that is it really worth messing round with brushes etc? plenty of bargains about.
Well, depends really - if you can get new brushes for a couple of quid, then that's £28 plus post that can go on beer/curry/whatever....
Thanks for help.
I am going to play safe and get an alternator. Will try Ebay but if any better ideas then let me know.
John
John
The brushes really are incredibly easy to change and cheap too - I don't recall any soldering when I changed mine, or I'd probably have avoided do it - any decent auto-electrics place will do them. I'd be tempted to try that first.
Dom
91 TZD
02 Picasso HDI
'12 DS5
83 Moto Morini 500
70 Fiat 850 Spider
Anything that turns money into noise...
91 TZD
02 Picasso HDI
'12 DS5
83 Moto Morini 500
70 Fiat 850 Spider
thanks
john
john
