BXv 16 Door window rubbers
greendale65
Post by greendale65 »
Hello everyone, wanted door window rubbers for my bx 16v mine have shrunk any out there. Alan :|
Re: BXv 16 Door window rubbers
There the same on all BX's Alan, and to be honest they all shrink! so you may have to try and make some.
You want 16 of 'em?!
16valver
Post by 16valver »
i can check on mine. All doors i take it?
patersom10
Post by patersom10 »
If you do get some made up, I need some ! As I'm sure do others.
Greater volume should lower the cost.
Already had to replace one window channel due to corrosion
93 ZX Volcane TD
92 BX 16v phase 2 - now sold
93 BX 17TGD - now sold
Couple of suggestions assuming new bits aren't available. It may be worth contacting a trim company such as Woolies (if I've spelt it right!) To see if they have anything that'll do the job. It may also be worth contacting Chevronics - Rob's been building up a stock of BX parts and if there's enough demand he'll get parts made. I've bought parts from him for the GS and while he's not cheap, the parts he stocks are all good quality.
greendale65
Hello bx's. I've got some used ones coming hope they will be ok.
greendale65 wrote:Hello bx's. I've got some used ones coming hope they will be ok.
I doubt it, as Tim said all BX's have shrunk exterior rubbers.
