Does anyone know what the part numbers are for these?
And how many different types of cables are there?
Speedo Cable Part Numbers
demag
Re: Speedo Cable Part Numbers
I thought there was only one type. I don't know, just guessing.
Sent from my HUAWEI P6-U06 using Tapatalk
Dave.
1990 Bx TGS automatic.
There are several types of each half of the speedo cable. To my knoweledge there's top halves for MK1 drum type, MK1 GT / Sport type and Mk2. For the bottom half there's the usual one for 16, 19 and diesel, suitcase engine and possibly TU engine (although I'm not sure about that last one). Then of course there's different lengths for LHD and RHD.
how many part No. did you want
top section
95 638 113
SPEEDOMETER CABLE
96 043 276
NFP
1,905L AND PETROL AND 4X4
95 600 677
NFP
GTI 16S AND 4X4
96 027 855
NFP
SPEEDOMETER CABLE
LONG 1050
RIGHT HAND DRIVE
96 064 239
NFP
LONG 1230
4X4 AND RIGHT HAND DRIVE
lower section
95 583 772
NFP
SPEEDOMETER CABLE
1 360L UNTIL RPO 04252
96 073 325
LONG 485
1,580L AND PETROL
LONG 485
1,905L AND PETROL
LONG 485
1,769L AND DIESEL FUEL
LONG 485
1,905L AND DIESEL FUEL
LONG 485
1,905L AND PETROL AND BORD COMPUTER
LONG 485
1 360L SINCE RPO 04253 UNTIL RPO 04724
LONG 485
6123 A4
NFP
LONG 222
INJECTION AND 4X4 AND 1,905L
LONG 222
PETROL AND 4X4 AND 1,905L
LONG 222
4X4 AND GTI 16S
LONG 222
DIESEL FUEL AND 4X4
95 496 555
NFP
LONG 570
- GTI 16S
LONG 570
1,905L AND PETROL EXCEPT BORD COMPUTER
6123 G9
LONG 330
SINCE RPO 04725
95 496 555
NFP
SPEEDOMETER CABLE
LONG 570
DIESEL FUEL AND RIGHT HAND DRIVE AND 1,905L
LONG 570
DIESEL FUEL AND RIGHT HAND DRIVE AND 1,769L
LONG 570
RIGHT HAND DRIVE AND GTI 16V
LONG 570
PETROL AND RIGHT HAND DRIVE AND 1,580L
LONG 570
PETROL AND RIGHT HAND DRIVE AND 1,905L
95 583 772
NFP
1 124L AND 01
1 124L AND (GR)
1 360L AND RIGHT HAND DRIVE
top section
95 638 113
SPEEDOMETER CABLE
96 043 276
NFP
95 600 677
NFP
GTI 16S AND 4X4
96 027 855
NFP
SPEEDOMETER CABLE
LONG 1050
RIGHT HAND DRIVE
96 064 239
NFP
LONG 1230
lower section
95 583 772
NFP
SPEEDOMETER CABLE
96 073 325
LONG 485
1,580L AND PETROL
LONG 485
1,905L AND PETROL
LONG 485
LONG 485
LONG 485
LONG 485
LONG 485
6123 A4
NFP
LONG 222
LONG 222
LONG 222
4X4 AND GTI 16S
LONG 222
DIESEL FUEL AND 4X4
95 496 555
NFP
LONG 570
- GTI 16S
LONG 570
6123 G9
LONG 330
SINCE RPO 04725
95 496 555
NFP
SPEEDOMETER CABLE
LONG 570
LONG 570
LONG 570
LONG 570
LONG 570
95 583 772
NFP
1 124L AND 01
1 124L AND (GR)
- x 56
Looking at that, it says its the same for the Diesel, GTi & 4x4.
"DIESEL FUEL AND 4X4"
"4X4 AND GTI 16S"
That is rubbish! They are completely different!
The lower end of the 4x4 is a solid part coming from the transfer box to the upper end. The upper end then has a different fixing screw to attach it to the lower part.
Where do they get these ideas from?
"4X4 AND GTI 16S"
that list is copied and pasted from service citroen ( citroens own parts look up )
I bet someone in accounting decided that they could rationalise their parts listings and save a bit of money - it's notthe first time they've done this and got it wrong. Several years back Citroen decided that they'd substitute a standard high tensile bolt for the one with an undersized head that bolts the pulley onto the crank on a 2CV. Of course there's a reason for the undersized head - if it were any bigger the required socket wouldn't fit down the tube the bolt goes down!
Vantman
