1987 BX 1.9 RD Break bits required
classicnut5
Post by classicnut5 »
Have just returned to BX motoring and bought an 87 RD Break estate in belting condition.
Firstly would like to know if the clocks set up are interchangeable as I would like to upgrade mine to the fancier dash? If they are is it a complicated job? If so I need: :D
Instrument panel
Estate tow bar
Grey strip on dash top that houses demister slots
Plastic Light covers on interior pillars
Cheers :D
x 138
Re: 1987 BX 1.9 RD Break bits required
Post by rutter123 »
dash clocks are interchangeable, someone on here should have a towbar, dash top strip-you may be lucky and find an un-cracked one, same for interior light covers most of the have turned to dust.
Post by RxBX »
classicnut5 wrote:Have just returned to BX motoring and bought an 87 RD Break estate in belting condition.
Instrument panel
Estate tow bar
Cheers :D
Hi,
Would this be the Red 19RD Break E920 KHW that was recently F/S firstly on E-bay then Gumtree and which was then 'Polished/Valeted' and put back up F/S on C&C ?
classicnut5
It would indeed.
I have a genuine Citroen towbar for an estate, and wiring kit which just plugs into the loom (no need to mess with Scotchlocks). It had been offered to Threadbear last year but not sure whether he still wants it - however it's with another member at the moment so I'll need to find out its whereabouts if he doesn't want it!
classicnut5
Hi, will certainly have the tow bar, pending cost and if its still available? Please let me know the answer to both questions.
Russ
Post by RxBX »
Hi Russ,
Further to your decision in the TECHNICAL-SECTION on keeping the standard instrumentation set-up with the Analogue clock I've sent you a PM for that request !
