Headlamp covers
demag
Headlamp covers
Post by demag »
Are there rubber covers fitted to the rear of the headlamps? The back of the bulbs are open on the auto and there is condensation in the o/s headlamp.
Dave.
1990 Bx TGS automatic.
Re: Headlamp covers
You should be able to find covers that do the job at the local scrappy, although I'd also check the sealing of the headlamp glass, as they're known to fail to the point where the glass falls out.
Re: Headlamp covers
I doubt the condensation is getting in from the bulb opening, i suspect it will be on the front of the headlight which with age where the glass is glued on with that white stuff, it gets brittle with age & cracks & lets moisture into the light. Best to take the headlight off & check how secure the glass is, it may just pop off the headling unit, in which case you can give them a good clean & then use some builders caulk to re-glue the glass back on, guess how i know this ;)
Thread Bear
Re: Headlamp covers
Post by Thread Bear »
I seal mine to keep the water out, either repaired or otherwise. If there is an area water can get in, and its cold, the freezing forces the joint apart. No water ingress, no failure.
demag
Re: Headlamp covers
Post by demag »
Its only the o/s so will have a look thanks.
Sent from my HUAWEI P6-U06 using Tapatalk
Dave.
