Wanted - switches, light-grey if poss
As well as my HRW switch with no illumination, it seems the rear wiper switch is also rather iffy. Sometimes it works, sometimes it doesn't. Ideally, these switches in light grey would save me some bother, but I'm considering fitting all-dark/black switches as an interim measure seeing as light grey is not common. Sod cosmetics - it'd be really good to know if the HRW is on, and I'd like the wiper to work when it should! It's an estate, so needs to be the correct switch.
Re: Wanted - switches, light-grey if poss
Given that I found a HRW switch in pieces in my parts stash yesterday, then yes. So, any switches will do! Sadly, this HRW switch didn't seem to have a bulb in it. Which is perhaps why it was in pieces.
