Turbo Diesel Estate for Sale, has MOT until June.
Good Points, Very Solid, no obvious welding required,pipes look good
Excellent Interior , GTI Type
16 Valve Steering Wheel, Smooth Engine, very good on emmissions ( Though bad turbo lag)
Has Air Con , but needs recharge, 210k, Abs works fine.
1st owner was a courier, did a 140k in 1st four years.
Good Clutch
Has a set of GTI Alloys with tyres , but currently on steels with snow tyres
Bad points, needs radius arms doing,
Spheres gone a bit hard, pump a bit slow to rise
2nd gear occasionally bulkes on synrcho,
Drivers window needs new channel or repair ( window closed at present)
Turbo lag, I believe are all like this, power a lot more noticble above 2500,
Speedo has stopped working , but mileage is about 210
Dent in rear passenger door , probably would mostly push out ( Some idiot drove into it a car park)
Metallic Green/Grey
Too good to scrap, sale due to ill health
£300 ono, car near Buxton, Derbyshire.
Jason 07983 997253
Bx Turbo Diesel Estate , 1991,AIR CON
Jatoc
Re: Bx Turbo Diesel Estate , 1991,AIR CON
Sounds like a cracking project for someone!
- x 53
Did anyone hear any more about this? If I had the money I would have bought it myself.
