Clutch change gti 8v
My Cars: 65 Peugeot Boxer van 160k
Nissan Micra K13 the wife's run around
x 62
Post by rutter123 »
Not done a petrol before, done a few diesels, are they much the same to do? do i need to completely remove the o/s driveshaft or leave in situ drawing the gearbox from the shaft? i will be removing the rad makes acces around the fdv easier. Any tips to make life a little easier? is it this type where the thrust bearing has a nasty habit of falling off during re-assembly?
JayW
x 13
Re: Clutch change gti 8v
Post by JayW »
I really is pretty much the same. The bearing will depend which of the 2 fork arrangements you have, but if you fit it then use cable ties to tie the arm into position it'll stay on.
Even if you do magically manage to do it with the shaft in place it's gonna be more of a ballache than you can possibly imagine! I usually unbolt the intermediate bearing and bottom balljoint and withdraw them still attached to the hubs.
Doing mine tommorow funnily enough!
Post by David »
The only advise I can give is to remove the RH drive shaft, Otherwise you will be struggling for hours & risk the possibility of damaging the oil seal. If you remove the radiator & all the air pipes you will be able to see what you are doing & hopefully get it done a little easier. For what little time it takes to remove them will be worth it when your attempting to reassemble it.
Good luck & let us know how you get on.
2011 Ford Focus Zetec - Daily Driver. (Absolute bone shaker).
x 62
Post by rutter123 »
can i remove the bottom ball joint with the drop links still attached both ends?
JayW
x 13
Post by JayW »
Yes.
Provided the system is depressurised you'll be able to lift the hubs clear out of the arms by hand once you've broken the initial grip of the balljoints.
Did my clutch and gbox swap today, started at 9:30, finished at 14:30 with a break for lunch, including swapping the clutch fork over. The only thing stopping me driving away was having forgotten to take the new clutch cable with me #-o
Good luck!
x 62
Post by rutter123 »
Just about managed to limp it the 11 miles home today, be a job for the weekend i guess. remove top engine mount?
JayW
x 13
Post by JayW »
Not necessary, just the one on the 'box (obviously).
Once you've lowered the engine/box a bit with the trolley jack, completely remove the gearbox mounting stud and it'll make life a lot easier when it comes to space-to-move.
x 62
Post by rutter123 »
i was not aware that the gearbox mounting stud could be removed, i always thought it was pressed into the casing, i remember having trouble getting the tzd box back in with that stud getting in the way, how to remove it?
JayW
x 13
Post by JayW »
Unwind it, it's just a bolt!
You can use a spanner, but parrot-nose pliers if you have them speed things up a lot!
Post by David »
Its just a 16mm (I think) bolt. Get a long socket on it & undo it. It will make things a lot easier. You can normally get at it with the mounting removed through the battery box.
x 62
Post by rutter123 »
I seem to remember about an hour long battle getting the box back in the tzd, i'm removing the rad anyway as i have a new one to fit and for the sake of a few quid will replace the outer c/v gators whilst its all apart as they looking a bit aged. Will have a go at removing the stud to save a bit of time.
x 62
Post by rutter123 »
job done, no real probs apart from getting the mounting stud out of the gearbox (that was real tight), took about 6 hours including several tea stops from start to finish, so much better now. i'd guess it was the pressure plate that was knackered as the friction plate didnt seem that bad.
gearbox out
gearbox out
the offending items
the offending items
new clutch in place
new clutch in place
