Heater blower resistor fault
x 138
Post by rutter123 »
The heat sink type jobby that sits in the fan blower housing, mine has an intermittent fault somewhere inside its plastic housing, i guess a dry or corroded joint? it is not the plug as i am getting same voltage both sides of this but a break going to the heat sink, can the heat sink be removed from the plastic to aid repair? as it looks as tho its only clipped in has anyone got a remedy for repair or had any success or other suggestions, thought i had it sussed as it was all good on test outside the car but once refitted, no go.
Or failing that anyone got one for beer tokens?
electrokid
Re: Heater blower resistor fault
Post by electrokid »
Lots of heater how-to here...
http://www.bxclub.co.uk/forum/viewtopic ... 15&t=17847
and here...
http://www.bxclub.co.uk/forum/viewtopic.php?f=15&t=5515
I'm sure one of those includes a list of transistor types that can be used as replacements if needed - if not I have such a list somewhere - I'll look it out if you need.
2002 C5 HDi SX estate
Thread Bear
Post by Thread Bear »
The PCB board breaks rather easily, as I found out. You can take it apart though and other people have effected repairs. I was fortunate enough to have a replacement used item so my only input is to take care of the PCB board.
x 138
Post by rutter123 »
The problem seems to have fixed itself overnite, after re-assembling everything it refused to work on sat afternoon, sunday morning switched on blowing lovely all the way, left it running pulled/wiggled all the plugs, gave it a few knocks etc etc all seems well, so for now will leave as is.
thanx to electrokid for the link seems i may have binned a few pcb's over the years for no reason.
I know last year NEAT autos in west drayton had some NOS pcb's for £20 as fitted on my tzdt.
