Help, crank no start 16v
patersom10
So having put everything back together this weekend after changing my head gasket she won't start. I have replaced spark plugs, coil, there all good. New starter motor and battery.
Getting spark and fuel to rail, could I have damaged the crank sensor? Would this stop injectors?
A bit lost, any advice welcomed.
Put some easy start but all that did was smoke, timing all correct.
Thanks. Matt
Thanks. Matt
93 ZX Volcane TD
92 BX 16v phase 2 - now sold
93 BX 17TGD - now sold
patersom10
Re: Help, crank no start 16v
Had new dizzy cap and rotor
93 ZX Volcane TD
- x 94
Crank sensor could stop injectors firing at the right times. Download the diagnostics off the 16v forum and get your multimeter out!
patersom10
Cheers bud, will take a look.
Tax and Mot due in a couple of weeks and with the car on the road outside the house it's panic time !
93 ZX Volcane TD
Would this matter though? I think it's a batch fired injection system, so the injectors are mostly going to be firing against closed valves anyway. Wonder if lack of crank sensor signal would stop injectors firing at all though? In which case a noid light would be useful.Kitch wrote:Crank sensor could stop injectors firing at the right times. Download the diagnostics off the 16v forum and get your multimeter out!
- x 94
You'd get coughs and splutters I would think, but the injector timing is linked to the ignition timing in the ECU, so if they're both out of kilter it can have an effect.mat_fenwick wrote:Would this matter though? I think it's a batch fired injection system, so the injectors are mostly going to be firing against closed valves anyway. Wonder if lack of crank sensor signal would stop injectors firing at all though? In which case a noid light would be useful.Kitch wrote:Crank sensor could stop injectors firing at the right times. Download the diagnostics off the 16v forum and get your multimeter out!
RobC
- x 30
Have you checked the earth to the ignition module on the bulkhead? I remember I once had to splice that direct back to the battery because some wires broke. Also the earth point by the battery is a bit dodgy on J-HUF anyway, unless it's been tidied up properly since I owned it...
(edit: just saw you're getting a spark, so ignore that!)
1991 Citroen BX 16v
adamskibx
Even if the injectors could get away with firing at the wrong time, the spark plugs couldn't.
adamskibx
I would get hold of a strobe and paint some timing marks and see if it flashes when it should when trying to start.
patersom10
http://www.ebay.co.uk/itm/Crank-Sensor- ... 19e94e715d
anyone know the part number for the crank sensor, if its this one attached may as well change it. changed everything else !
93 ZX Volcane TD
patersom10
thinking about getting shipped to rob at chevronics, if he will take it on.
would I even be able to get it on a trailer as its at low?
93 ZX Volcane TD
- x 94
You can check all this stuff using a multimeter and the pins on the ECU plug. It's actually pretty easy to diagnose problems using the PDFs you can download from the 16v forum.
patersom10
Now for sale
93 ZX Volcane TD
patersom10
So having not sold my 16v, I have been tinkering with it.
Joy ! Managed to get it started today, unfortunately it then decided after 1 min of running to dump all its oil and coolant.
Have found the source of the coolant dump (cracked hose behind block)
However the oil is a bit strange, the oil filler cap blew off causing the car to be decorated a lovely light brown colour. I presume it's high pressure.
Any ideas ?
Any ideas ?
93 ZX Volcane TD
Could be that you detonated the petrol/petrol vapour accumulated in the sump following all the extensive petrol metering of the injectors without a previous start?patersom10 wrote: However the oil is a bit strange, the oil filler cap blew off causing the car to be decorated a lovely light brown colour. I presume it's high pressure.
Any ideas ?
