Reply-To: J HAWES <j.hawes227@btinternet.com>
Can you please let me know, Tim, how to turn the crankshaft on my BX, so that I can check the timing. You see I changed my distributor before I realised that I have got no timing plate! My mentors, at my local garage, told me that there is another way of BX timing on some BX models. I've bought a gauge to show me when the cylinder is at the top, but the instuctions assume that my car is so old that the engine is an in-line, so that I can easily get to the crankshaft to turn the engine round, The Haynes book, so very good in some ways, but not in others! Do you know where I can get any information. Also, I don't know if you can put me on to anyone who can find me a Solex carburettor to practice taking to bits. Also I should like a spring tensioner, to enable me to get that big ( 2 inch/50 mm), spiral spring back on, afterwards. John Hawes.
How do you (email from a fellow BX'er)
1985 CITROEN BX 19GT C1TBX
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1991 BX 19TZI Auto A/C
1994 Xantia 1.8i SX
1972 Morris Marina 1.8 SDL
1979 Rover SD1 V8-S
1980 Morris Marina 1.7 HL
2003 Rover 25 1.6i XL 5 DR
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
- x 57
Re: How do you (email from a fellow BX'er)
A) What engine is it?
B) It is an in-line engine. All BX engines are. You don't need a tool to find TDC anyway, just a thumb and a mate
1983 16TRS (Sunrise red) - 1987 GTi 16v (Black) - 1989 16 Valve (Venetian red) - 1990 16 Valve (Venetian red)
Put a spanner on the crankshaft pulley bolt head and turn it?
- x 13
Its a 1.6 carb bx sorry.
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
- My Cars: BX 16v Ph2
- x 20
If the engine/gearbox is in the car, put one front wheel in the air and one on the ground (to overcome the dif), stick it in gear, and turn the wheel by hand. The gearbox will then rotate through to the engine and crank.
Even easier if you have 7 spoke 17" alloy wheels.
Tahnks Vanny.
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
