Having chatted to Rob Moss on Sunday he confirms the TZI probably has a cracked exhaust manifold, the symptoms suggest it as its noisiest when cold and under load then quietens as it warms and the metal expands.
Thanks
TZI/GTi 8v Manifold Wanted.
- Tim Leech
- x 148
- JayW
- x 13
Re: TZI/GTi 8v Manifold Wanted.
Surely the gasket would be the first suspect? The manifold is pretty easy to view top & bottom with a decent torch.
- Tim Leech
- x 148
Apparently its quite common on those, if its a hairline crack and underneath its going to be quite hard to see. If it is the gasket I would rather have a spare manifold standing by just in case as its gotta come off anyhoo.
