parts required
TouaregUK
parts required
Post by TouaregUK »
Any one know where to get a speedo cable.
thanks
Lawrence
TouaregUK
Re: parts required
Post by TouaregUK »
forgot to say for BX TZD 1.9 non turbo
Lawrence
Re: parts required
Top or bottom as all Mk2 speedo top cables are the same, new ones are not available so you nee dto find a used one OR have one made up.
TouaregUK
Re: parts required
Post by TouaregUK »
Its the top speedo cable,.
Mk 2 so there all the same.
what about getting one from France
also some one said there's a company that makes them
will run 30 off, any one any ideas.
Lawrence
x 138
Re: parts required
Post by rutter123 »
I have a complete speedo cable from a 19tgd upper/lower tho the top plastic collar is broke iit was working ok like this, could be repaired i would think if it gets you out of trouble.
