Various bits for grabs bx
Pair of o/e front wishbones marked v260/261 needs new bushes
Diesel starter motor 17/19d/td known good
Front bumper brackets pair with all good lugs
Complete upper/lower speedo cable the upper plastic collar is broke but still works ok
Torque converter 19tgd Sachs
Auto gearshift lever and selector window
Auto bottom gearbox cover plate and pipe bracket
Hyd pump base bracket (auto box) think they differ from manual
Hyd pump adjuster bracket
Auto pedal box good and solid
Auto brake pedal rubber
12 standard wheel bolts (steels)
2 bonnet buffers
1 thrust bearing ball pivot type gti/d
1 bonnet switch
3 bayonet headlamp fixings no pins
1 o/s/f bumper trim blade
1 fuel rail gti
1 boot light switch and lens
1 foglamp back needs chroming but still intact with lampholder and rubber seal
1 bumper/splitter insert
2 bonnet buffers
1 bonnet switch
1 fuel rail gti
Re: Various bits for grabs bx
Hi bud,
i would be interested in the auto gear shift lever and selector window if its for a RHD motor, ie the numbers etc are on the rhs of the plate.
From a 91 rhd tgd so should be ok.Mothman wrote:Hi bud,
really?
Hi there, would like your front bumper brackets please.
Could you pm me with details please. Thanks
Didnt answer my question bud.rutter123 wrote:From a 91 rhd tgd so should be ok.Mothman wrote:Hi bud,
Ime only interested if the selector window is on the RHS, not interested if its not. Can you see it all when you are driving the motor? Piccy would sort this.
None of the selectors were made with the window on the right hand side, you have to modify them.
Defender110 wrote:None of the selectors were made with the window on the right hand side, you have to modify them.
Sorry Kev, thats incorrect, the very late ones did have a RHD selector, I got one off a K plated 16TXI auto that was broken and fitted it to the TZI, but had previously adapted the existing one with some superglue and fiddling.
- x 59
I can't remember what side my selector plate was on, But I don't remember any issues in seeing it. I will have to find it & look.Tim Leech wrote:Defender110 wrote:None of the selectors were made with the window on the right hand side, you have to modify them.
I still have my auto pump bracket on my manual 4x4 gearbox & it fitted fine, So I assume they are the same.rutter123 wrote:Hyd pump base bracket (auto box) think they differ from manual
I stand corrected, mine was on the left originally and I too had to adapt it to the right.Tim Leech wrote:Defender110 wrote:None of the selectors were made with the window on the right hand side, you have to modify them.
Just to clarify the selector window is to the right of the shifter.
rutter123 wrote:Just to clarify the selector window is to the right of the shifter.
A worthwhile upgrade then for someone with an auto!
bx petrol auto saloon
Dear Andy,
Just had a quick shufty on mine and the " window " with the letters are to the right of the gearlever
I hope this Andy
Vince,
I hope this Andy
Vince,
47,594 Miles from new.
Owned for 3 years sorned.
69,000 Miles from new.
Owned for 15 years T & T.
demag
How do you mod them then? Mine is on the left.
Dave.
1990 Bx TGS automatic.
stevieb
would he bumper trim be the wide black strip mounted on the surface?
Stevieb, the bumper trim is just the small blade that fits to the rear of the bumper just below the front edge of wheelarch, about 2 inches long.
