wanted
Stinkwheel
Re: wanted
headlamps are cheap enough new (see the dreaded e-bay)
Im afraid upper speedo cable may be more tricky, they are not available anymore from citroen, or anyone it seems.
Some folks did have one piece cables amde up but i know little detail im afraid.
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
Re: wanted
georgemckeown wrote:drivers side headlamp and top end speedo cable new or second hand
Matt, the only THREE that are currently showing listed on E-bay are for the N/SStinkwheel wrote:headlamps are cheap enough new (see the dreaded e-bay)
Im afraid upper speedo cable may be more tricky, they are not available anymore from Citroen, or anyone it seems.
Some folks did have one piece cables made up but i know little detail im afraid.
Hi George and welcome to the BXC, I'll have a look thro' my spares stash for you tomorrow to check if I've an O/S unit available !
For the 'one-piece' bespoke speedo-cable take a look at THIS thread !
I hope that maybe of help ?
georgemckeown
Re: wanted
thanks for your help even a second hand headlamp would be fineStinkwheel wrote:headlamps are cheap enough new (see the dreaded e-bay)
georgemckeown
Re: wanted
thanks that would be great if you have oneRxBX wrote:georgemckeown wrote:drivers side headlamp and top end speedo cable new or second handMatt, the only THREE that are currently showing listed on E-bay are for the N/SStinkwheel wrote:headlamps are cheap enough new (see the dreaded e-bay)
Some folks did have one piece cables made up but i know little detail im afraid.![]()
Re: wanted
I have an O/S headlamp available, PM sent !georgemckeown wrote:........
