Hi all,
I have found 2 steel wheels in the shed that need a new home.
I think they could have been originally off a Peugeot, but they fit the BX fine.
The tyres are cracked & would need replacing, but the wheels themselves are, apart from some surface rust, in good condition.
They are the type that have holes in them.
£5.00 each or make me a offer.
I can have the tyres removed & disposed of if need be.
Collection only from east Manchester.
2x Steel Wheels For Sale.
- x 56
- x 56
Re: 2x Steel Wheels For Sale.
The tyres have now been removed from these. If no one wants them then they'll be going for scrap.
Hi David,David wrote:Hi all,
I don't want to scupper a sale for you, but from the photo's I can only see the 'Hub-Hole' and the four holes for the 'Wheels-Bolts' !
Therefore albeit they may be okay for the front fitment on a BX, how would you fit the rims to the rear (With-out modification) as the rear-hubs should have a disc to hub retaining set-screw with an integral wheel positioning location pin and as such a BX wheel rim has an extra hole for this feature !
- x 56
Thanks for pointing that out. In all honesty I hadn't noticed that & only tried them on the front of mine. Although if the positioning pin was removed from the rear & replaced by a screw then they would go on the back fine.
jeremyC5
So what is the point of the pin, if it is not required on the front wheels, only the back ?
C5 x 1
Ford 100E - Red x 2
Herald 12/50 x 1
Ford 100E - Red x 2
Herald 12/50 x 1
