door card membrane / sound deadening
themildbunch
Post by themildbunch »
I need to strip down some doors on my BX and other interior areas for some welding soon and remembering the state of the door membrane wondered what's a good product to use to replace my cut about one?
While I'm at it - what are some good, but not dynamat priced panel deadening / noise insulating material that could make the cabin a bit quieter?
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
Re: door card membrane / sound deadening
this type of material????
http://tinyurl.com/moe2ocg
or
http://www.caraudiodirect.co.uk/deadeni ... e-coatings
just do a gooooogly search
electrokid
Post by electrokid »
Fablon or just plain polythene sheet works well for the door membrane. Silicone rubber can add weight to panels and reduce flex at corners but make sure not to block any drainage routes: if it's around or near to any electrics then use a neutral cure. I've not had any problems with the normal acetoxy cure silicone elsewhere - bodywork / gaskets etc.
2002 C5 HDi SX estate
the other thing for the membrane is heavy duty polythene attached with aerosol adhesive
I understand self adhesive lead flashing is an excellent panel deadening material, in fact I know someone who buys it and repackages it as a sound deadener and sells it on at a great profit margin.
Tinkley
Post by Tinkley »
Defender110 wrote:I understand self adhesive lead flashing is an excellent panel deadening material, in fact I know someone who buys it and repackages it as a sound deadener and sells it on at a great profit margin.
Must be the 'Bulletproof' version.....Day of the Jackal anyone..... :wink:
BXImage
Post by BXImage »
Had the same problem when mounted rear power windows on my BX. If we are talking about same thing, sound deadening material is called "termosilent"(http://www.laminat.co.rs/wp-content/upl ... dloga4.jpg) and is about 2 mm thick. The good thing is, that same material is used as isolator under the laminate and price for 4 square meters is just under 4 euros. It can be glued to the door with Henkel universal glue - http://www.electrotools.gr/1096-2244-th ... t-125g.jpg, as it doesn't burn trough. Here is how it came out on my rear doors:
themildbunch
Yes, thanks - I just remembered about laminate underlay. I'm sure I read that one this forum somewhere years ago... You can get a big roll from Ikea very cheaply...
1988 BX 19 Gti 16v
