Reason being, having removed the trim cover and duck tape, there is not a lot holding the rear most bolt from waving in thin air!. In fact the thin bodyshell part is slightly bent at one corner so I assume it has been flexing. The bolts should come off OK, bit naughty the guy who had it before, dropping the frame and welding the boot floor but neglecting this bit. In fact I would say negligent as less safe than the boot floor collapsing.... Although I can 'bodge' this, it is not simple or easy. In fact I am actually reluctant to even drive the car (as is) having seen the extent of the rust and holes. It is actually pretty hard to discern how the original assembly of bits fitted and/or was welded together.
Surprisingly it is only around that bit that there is dangerous corrosion, some of the rest of it is better than expected, maybe a spot or two around the bump stop, but the sides were only surface rust. The upright flange is not bad either.
Hopefully, I can save this beast from 'doing a Jaba' because perhaps I have caught it in time.
Just checked the other side! No daylight visible, obviously a semi closed box construction. Some light rust but obviously original. It now becomes clear that someone previously has tried to 'repair' the o/s and put a mild steel piece in complete with special hole (about 25mm diam) to let even more salt water into the semi sealed box construction. Great, that makes me glad I did not take it to Lake Garda (towing boat) last week, it would definitely have collapsed either on the pave, or in the Alps.....
The replacement 'steel' piece ressemble mille feiulle layers of lovely brown stuff. Now I have a few options. 1. Leave it where it is, on drive and get mobile welder to have a go at it, with subframe dropped a few centimeters. 2. Run it somewhere it can be welded properly and get a set of rear pipes, drop all the rear and sort out properly. 3. Better not detail, but can 'repair' myself, believe me it would be stronger than what is there and possibly than original but may not meet approval!.
Anyone know a half decent mobile welder on the Surrey/Hants border?
