parts for mk2 bx wanted
ststech
heres my shopping list so far
im looking for a pair of electric mirrors plus interior caps black as the last owner put manual ones in also the little plastic trim goes round indicator stalk black rear window switch the radio door assy 2 rear headrests black flywheel sensor as rev counter not working drivers speaker grille black and if im realy lucky set of tzd wheel trims or it looks like halfrauds sorry for large shopping list lol but its been a few years since i had one lol i may consider a complete car if anyone scrapping one tzd or gti
i would be ok with manual mirrors as long as trim cover from inside with them
thanks in advance Simon
2007 c4 grand picasso exclusive 2.0 hdi 138 egs
1993 bx tzd turbo estate silver undergoing restoration
Re: parts for mk2 bx wanted
Im breaking a j plate tgd most bits available, grey interior tho.
TZD usually came with only one electric mirror, the passenger side as if you fit 2 then the control will just move both at the same time. Drivers side just had a manual.There are often the flywheel sensors for sale on feebay.
Somewhere i may have a spare electric mirror but as ime possibly moving soon may have difficulty finding it as ive just piled all my spares into an outbuilding and its a huge pile. Wont be cheap though as they are quite rare, its new old stock.
ststech
i have repaired radio cover think i can live with manual drivers mirror
but am still needing a rear elec window switch the little round cap that goes over manual mirror stalk
a speaker and grille
may need other bits when i get round to looking
I have all of this but its grey apart from the mirror slalk insert which is black.ststech wrote:i have repaired radio cover think i can live with manual drivers mirror
Mike E (uk)
I have all the trim parts & switch, in black
pm me to arrange.
Mike
pm me to arrange.
Mike
ststech
ps i have lexia does anyone know where the 2 pin diagnostic plug is on a tzd
ststech
also looking for clock bulb and holder and handfull of panel lights for heater controls and instrument panel
and pair of front speakers and rear tweater grille round one
thanks in advance
thanks in advance
ststech
now looking for a passenger side wing in silver
and its been a while since i owned one but what causes speedo needle to flutter in operation is it cable or speedo head in the instrument panel
thanks in advance
thanks in advance
ststech
god my mind must be asleep
this is a stab in the dark but does anyone have the rear bumper insert black rubber i think it should be like the front for tzd estate am hoping citroen still stock the clips
KevR
I've got some standard speakers, but you're much better off getting some decent Pioneer or similar to fit - they're a standard size. Could probably find a rear grille, but someone must have one that's in the same country as you!ststech wrote:also looking for clock bulb and holder and handfull of panel lights for heater controls and instrument panel
thanks in advance
I've got a pair of rear headrests, but they're blue cloth.
ststech
have managed to find a lot of parts but still need the following
drivers side rear door inner window rubber strip
passenger side front wing in silver
rear speaker grille little round one near parcel shelf in black
front speaker grille drivers side in black
passenger side end of dash air vent
rubber sleeve that goes on ignition barrel
also the large bronze coloured screw that holds door handle on as i have one missing and cant find a suitable screw
speedo cable or advice on how to stop speedo fluttering lubrication poss
rear headrests in black
also stab in dark rear bumper rubber insert with clips as no longer available
thats all for time being thanks in advance Simon
also some useful info i was looking for a flywheel position sensor as rev counter didnt work and as citroen no longer stock 99% of bx parts i went on the bay and bought a used saxo 1.5d fp sensor it fits
and works just need to chop and swap plugs
ststech
got a set of 5.25 inch jvc speakers new on ebay (saxo fitment) fitted and work a treat
KevR wrote:I've got some standard speakers, but you're much better off getting some decent Pioneer or similar to fit - they're a standard size. Could probably find a rear grille, but someone must have one that's in the same country as you!ststech wrote:also looking for clock bulb and holder and handfull of panel lights for heater controls and instrument panel
thanks in advance
