Does alternator from 1.6 engine fits in 1.9 Diesel.
BXBulgaria
Post by BXBulgaria »
Thats the question :) help. [-o<
x 138
Re: Does alternator from 1.6 engine fits in 1.9 Diesel.
Post by rutter123 »
Maybe, depends of the amperage of the alternator, i think a diesel needs 80 amp and the pulley might be different.
Tinkley
Post by Tinkley »
You need to check the amperage. Valeo alternators and exchange ones are still available for the 1.6 ASFAIK. The normal BX use a 4 V belt but the aircon models have a 6 V belt so wider pulleys and obviously a different width belt. Again ASFAIK these are still available. I changed a normal 4 V belt one last year.
Post by Mothman »
Turbos, or at least my TZD had a 5V belt. Now works just fine with a 4V belt, bunging out 14.1 volt.
electrokid
Post by electrokid »
My 1.9 diesel started out with a 5V belt and a 50 amp alternator. I think you only get 80 amp alternators where aircon is fitted and they come with a 6V pulley.
2002 C5 HDi SX estate
KevR
Post by KevR »
ISTR trying the old alternator from my 1987 1.6TRS in a TZD and it didn't fit, but I can't remember why! Probably wrong pulleys. Might still have it in the shed somewhere, will try and take a look later.
