The last two fill ups (brim to brim) as always I noted fuel consumption had gone from the reasonable (for here) 10-11 miles per litre down to 9.5 and 8.74. This got me a bit perplexed given the last tank full has been used for a couple of long runs. However she also has been doing a bit of hill climbing in cold weather up to the ski area. This last fill up was bit surprise and yes I do keep good records.
One note though is I have done an oil change in the last 100 miles cut down on a bit of smoke it also seems. Would there be a fuel pump issue I need to attend to or could adjust? Not encountered this before certainly not this heavy a fuel use in 30,000 miles driving this BX.
Diesel Heavy Fuel Consumption
1990 BX19 TZS Auto 06/11/1989
electrokid
Re: Diesel Heavy Fuel Consumption
Your '92 TXD possibly has the later plastic fuel filter housing just above the fuel warming thingy - the plastic housing is prone to cracking and can leak fuel. It should be still available since it is used on later models (Xantia ?) but it's a long way from cheap.
2002 C5 HDi SX estate
Brian
Hi,
Check the easy items first:-
1 Wheels running free - braked binding ?.
2 Change the air filter.
3 Diesel fuel leaks?
Good luck
Good luck
Visa 17D 1986 192K Sorn
BX 17TZD 1992 192K
306 XRDT 1996 175K
BX 17TZD 1992 192K
306 XRDT 1996 175K
Checked! I am going to see if cold weather factor and hill climbing made a huge differance. Potential those soft winter tyres played a factor as it was also rather warm when I did the long runs. So this is still ongoing.
