I need some seals for my BX 4x4. The usual guy I get them off hasn't got any that fit. I need the large one that goes around the propshaft drive in the transfer box & at least 1 rear diff seal (the left one if their different).
Anyone got any ideas where to get some?
Where to get rear diff seals & rear transfer box seals?
- x 56
Re: Where to get rear diff seals & rear transfer box seals?
If you have a sample then Manchester seals will be able to match it no problem, they have now integrated into HTS but still brilliant and never failed to match a seal for me.
http://salford-city-of-salford.cylex-uk ... 79179.html
And if you don't have a sample, it's likely to be a standard size rather than made for the specific application. So you could just search by size, obviously the ID and OD being the critical dimensions.
http://simplybearings.co.uk/shop/Produc ... index.html
assembled
- My Cars: 1991 Citroen BX TZD TURBO 4WD*
*aspirational - x 2
Gearbox shaft seals:
2209 28
GEAR-BOX SHAFT SEAL
92 X 3,53
3206 20
PINION SEAL
30 X 5,3
2211 36
BOX WEATHERSTRIP
57 X 73 - 5,3
Rear diff seals:
3121 13
GEAR-BOX SEAL
45 X 62 - 10
3010 13
O-RING
78 X 84 - 3
I suppose those are standard as long as you are able to get right dimensions.
2209 28
GEAR-BOX SHAFT SEAL
92 X 3,53
3206 20
PINION SEAL
30 X 5,3
2211 36
BOX WEATHERSTRIP
57 X 73 - 5,3
Rear diff seals:
3121 13
GEAR-BOX SEAL
45 X 62 - 10
3010 13
O-RING
78 X 84 - 3
1991 TZD Turbo berline
Ex 1992 TZD Turbo berline, aircon, ABS
Ex 1989 GTi 4x4 berline, ABS
Tinkley
- x 8
and the right material......assembled wrote:Gearbox shaft seals:
assembled
*aspirational - x 2
Guys at specialized store should know the right questions to ask and what to offer for such application.
