Valve Springs Part Number Question
jamescarruthers
x 37
Post by jamescarruthers »
Could anyone with access to the correct Citroen manuals please tell me if the valve springs 0952.55 are for the 1.4 litre 150 engine or the later TU engine, please?
I got a set cheap but I wasn't sure which 1.4 they were for.
1987 Volvo 480 ES
Previous BX's:
A966 XRL -- BX 16 TRS
H767 BEG -- BX 14 TGE
B316 AMP -- BX 14 E
Tinkley
Re: Valve Springs Part Number Question
Post by Tinkley »
No idea, but the recommendation was to change valve springs every 30k on the 150C...... :wink:
here are all the BX listings coming up with that part No.
so TU is the answer to your question
(XT) EXPORT AND PETROL AND 1 360L AND MONOPOINT INJ AND CYLINDER BLOCK CASTIRON SINCE RPO 05440
PETROL AND 1 360L SINCE RPO 04193
PETROL AND 1 360L AND CYLINDER BLOCK CASTIRON SINCE RPO 05440
PETROL AND 1 124L AND 01 AND (GR) SINCE RPO 04193
here are all the citroen models on an all families search on that No.
1 document(s) found for BERLINGO
2 document(s) found for SAXO
4 document(s) found for C15
6 document(s) found for ZX
4 document(s) found for BX
5 document(s) found for AX
1 document(s) found for XSARA
jamescarruthers
x 37
Thank you very much Malcom.
1987 Volvo 480 ES
Previous BX's:
B316 AMP -- BX 14 E
