Bx mk2 solid shell
Bx mk2 solid shell
In 2 weeks time i shall be left with what is basically a good solid shell mk2 hatch a/b/c pillars boot floor chassis all solid, inner fronts been welded, bit of rust on rear cross member under bumper but generally pretty solid, anypne interested in taking it away for free, a good base for a project, or it goes for scrap. It may still have the eng/box in it if no one takes that.
Re: Bx mk2 solid shell
Do you have a front subframe with it?
Hi Tinkley, i will be keeping the front subframe as a spare as its in very nice cond. It will just be the shell with a bit of int trim, no mechanicals.
Pity, I would need to find one (front subframe). I suppose Daisy's would still be OK if Rob Moss still has her, and it should be in good nick if Chevronics restored her.
Seems good ones are v hard to find now hence keeping the One from the breaker. My previous tgd, rip, had a rusty front sub, i suspect oil leaks have kept the rust at bay over the years on some.
