Does it look like I'll have to drop the tank for this or can it be got too from underneath?
I wish it was that pipe but sadly the leak does seem to be from the breather on the nearside of the tank... The car had sat for some months until recently with little fuel so I suspect this hadn't helped an already old pipe.. It might be possible to semi lower the tank without removing the exhaust / height corrector linkage to get to it... Nasty job without a ramp really!Way2go wrote:If you have the auxiliary fuel tank, there is a large bore connecting pipe below. I did experience the top part of this pipe slipping off the plastic connector. Repair was as simple as loosening the clip, popping it fully back on and retightening the clip.
