Flushing Hydraulic System
Slagtrooper
Post by Slagtrooper »
I know that the correct answer is: Use Hydraurinçage.
But, if that product doesn't exist anymore in the market? I called a couple of Cit dealers, oil houses, etc. and some didn't know what was Hydraurinçage (Or Hydraflush) or said that they didn't have in stock, because they deal only with LDS systems that don't need that.
What can i do? What kind of product can i use?
I'm afraid to open the parts for cleaning, leading to rupture the rubber seals. I can't find easily its repair kit.
Regards,
Citroën BX GTi 1993
. XU9JAZ engine, ZF 4HP14 Automatic gearbox
. Leather Seats, Air Conditioner, electric mirrors, windows and sunroof
. "16V type" Speedline Rims, "Ducktail" spoiler and rear vents
ORGA 5219 (February 22, 1991) - Made in Uruguay
Hot steamy night alone, I wait for you ? Cold brittle morning alone and I cry for you ? And when you finally call ? You cloak your moves in the shadows ???
Re: Flushing Hydraulic System
GSF still sell TOTAL Hydraurincage or at least did so a fortnight ago - and there's some new old stock on eBay too: http://www.ebay.co.uk/itm/5lt-Hydraurin ... 1111983154
Malcolm Lockwood usually has some in stock. http://mlockwood.org.uk/
Just realised you're in Brazil. Some people swear by using some diesel as a flushing agent. Obviously not leaving it in the system as long as Hydraurincage.
Slagtrooper
Yeah, it's only for running the product in the system and filling with LHM later.
About the site: Nice one, but sadly our import policies are abusive for ordering some of these. We are charged with 60% of the product price in taxes.
So, if i fill with diesel, "citrobic" the car, drain (from the reservoir and vacuuming the tubes/brake nipples with a vaccum machine) and then fill the system with LHM, it could get better?
Thanks for the fast reply,
Bruno
Citroën BX GTi 1993
It should certainly clean out the system. Diesel acts as a lubricant, so the hydraulic pump and it's associated seals shouldn't suffer, but as stated, don't leave it in for extended periods of time. You're most welcome Bruno. :)
P.S. Don't forget the edge of the LHM tank/reservoir is razor sharp.
The diesel idea comes from our scandinavian cousins, perhaps find their website to find out a bit more info. TBH, diesel is a lot cheaper than hydraflush, so it may very well be the best way to do it. I've got no idea on how many miles you should leave diesel in the system & i'm also unsure if you can safely run it on a 100% diesel or whether it has to be mixed with lhm?
As modern diesel fuel contains detergents to clean the fuel rail and injectors, I'd hesitate a guess and say it's more 'aggressive' than Hydraflush. Personally, if using diesel as a flushing agent I wouldn't leave it in for more than a couple of hundred miles, just to be safe.
But then again there some who never use lhm, they just use hydraflush all of the time.
