seems to be the part I need to fix my 16v. Thanks
My 16v power syeering flow distributer
greendale65
Hello all, Can anyone give me a picture of a flow distributer for my bx 16v
16v
Re: My 16v power syeering flow distributer
The 'FDV' is the 'Block/item' in the middle of the image (Below) painted Greengreendale65 wrote:Hello all, Can anyone give me a picture of a flow distributer for my bx 16v
16v
The /\ image taken from THIS thread for ref. where you can see more of the internal bits !
Also read thro' THIS thread for more info, However the 'OP' images have gone though
('Mat F' , I wonder if 'cauchoiskev' has accidently deleted them from his 'Image-shack' account) ?
Without them it makes the thread harder to dechipher
greendale65
Thanks for that it seems this must be the part I have one in myRxBX wrote:The 'FDV' is the 'Block/item' in the middle of the image (Below) painted Greengreendale65 wrote:Hello all, Can anyone give me a picture of a flow distributer for my bx 16v
16v
Also read thro' THIS thread for more info, However the 'OP' images have gone though![]()
spares dept. Its to do with the pas which is heavy due to some
mechanic pinching lhm pipe they drained fluid all ok but the
steering being heavy thinking this must be the part restricting
the flow being blocked up with muck don't know.
If they've drained the fluid are they sure they've properly bled the system when refilling?
Tinkley
- x 8
Second that, and maybe bleed the brakes through so that the FDV near the back of the front subframe gets any air out. Normally not a problem if just emptying the reservoir, but if you take any hard pipes out, it seems worth doing. Usually I've had to bleed the front brakes anyway, ie flexys, front subframe (hard pipes changed) replacement so not noticed massive problem, only an airlock somewhere which resolved with enough playing with suspension height and releasing the pressure regulator screw. So worth a little more tinkering. Also the accumulator sphere definitely affects brakes and steering pressure so ensure it is at good pressure or replace.citsncycles wrote:If they've drained the fluid are they sure they've properly bled the system when refilling?
greendale65
Thanks all for helping me with my 16v I do miss
it ,should get it back today .
greendale65
Re: My 16v pas still heavy
Hello all, My garage just phoned and said they cant fix my bx16v car.
What happened in the first place took the car to garage for back
halve exhaust they pinched a LHM pipe and replaced it refilled
with new LHM but the steering is heavy they cant fix my car
any idea what the problem is its not not gonna cost me
as they damaged the the car they have had the car
and tried every thing .
You really need to get the car booked in with a garage that is conversant with citroens hydropneumatic system. There are a number of good citroen independent garages across the country but it's very difficult to give a recommendation as you do not list your location in your profile. If you update your profile or post where you are I am sure someone will be along soon to give a good recommendation of the most local specialist to you.greendale65 wrote:Hello all, My garage just phoned and said they cant fix my bx16v car.
greendale65
Way2go wrote:You really need to get the car booked in with a garage that is conversant with citroens hydropneumatic system. There are a number of good citroen independent garages across the country but it's very difficult to give a recommendation as you do not list your location in your profile. If you update your profile or post where you are I am sure someone will be along soon to give a good recommendation of the most local specialist to you.greendale65 wrote:Hello all, My garage just phoned and said they cant fix my bx16v car.
Hello, I live in Worthing , But as said the garage where my car is
said there will be no charge to sort this problem out
they told me today that they was getting citroen bx
specialist in to do the job.
they have only had the car for 5 weeks
some garage .
