Cupro Nickel 3.5mm tubing
Tinkley
Post by Tinkley »
I need to get hold of some of the 3.5mm 'hard' piping. Preference is C(K)unifer as this is a must over copper, which should NOT be used. Pleiades have run out! Any other sources out there?. I expect 10 meters would do the trick and replace all 4 front to back pipes. Basically the car was OK but sucumbed to the extra pressure on one pipe after Citrobics on replacing the rear subframe. Otherwise she should survive another year or two!.
Any other sources of supply? I note there is Bonapart just SE of Paris at about £26 for 10 meters and Automec (UK) at £45 for 7.6 meters. Just wondering if any of you know of other merchants/suppliers.
Do I need to use brass connectors with this type of tubing?, or are new steel ones OK.
x 103
Re: Cupro Nickel 3.5mm tubing
I used to buy from Bonapart 2cv until they moved to France and the quality of there stock was excellent.
It's worth googling for 2cv brake pipe as this is how I usually find the unions and seals.
Tinkley
Post by Tinkley »
Thanks guys, I'd found the Bonapart supply, I note in 10m lengths +, not the 25' lengths of the more normal imperial. I have supplies en route.
Surprisingly hard to find a merchant/factor who sells it 'off the roll' in the UK.
x 116
Am I misreading this - Pleiades have sold out of 3.5mm kunifer and no longer supply pipes made to length ???
Tinkley
Post by Tinkley »
Pleiades have no stock of 3.5mm tubing at the moment, they are getting some more in but about a month wait. As I would like to get back on the road a lot quicker than that, I've not had much option.
Post by Mothman »
They regularly run out of it. I had to wait 2 months for some from them a while back. But, cant do anything about it.
Tinkley wrote:Thanks guys, I'd found the Bonapart supply, I note in 10m lengths +, not the 25' lengths of the more normal imperial.
Bonapart do list 25m rolls of 3,5mm pipe
http://www.bonapart2cv.com/
i couldn't find there carriage charge on there site,
NeilGP
Post by NeilGP »
Also check ebay for 25foot in London
£44.95 free delivery
http://www.ebay.co.uk/itm/Brake-Pipe-Co ... 2a2f5c2e3c
Neil
A476 RBX
Series 1 BX 16TRS
NeilGP wrote:Also check ebay for 25foot in London
Neil
that seems a lot of dosh for just 7.62M
