Hi chaps
Using the search function I can't seem to find exactly what I'm looking for, so - being a bit lacking in mental agility today, for some reason - I have to ask, what LEDs do I need to buy as I'm intending to change all the dashboard lights and want it to be a one-time job.
Also, whilst I'm doing that, what other jobs should I consider doing seeing as some things might be more accessible?
I am lazy. Or dumb. Or both.
- x 27
Re: I am lazy. Or dumb. Or both.
Do some preventative maintenance on the speedo cable while you've got the binnacle out and run some three-in-one oil down it.
Leobx16v
The LED's are super bright in comparison with the standard bulb personally I wouldn't bother with a bx dash board because it may look like it has bright spots where the bulbs are
1991 Citroen BX 16v - Red
1991 Citroen BX 16v - Silver
1992 Citroen BX 16v - White
Scrapped:
G650PGX 1989 ph.2 red BX 16v
G-VOT 1989 ph.1 White BX 16v
Scrapped:
- x 27
Well I think as I have about 20 dash bulbs in a box here I might as well use those, thanks
and I have some Three-in-One...
This might help for the how-to:
http://www.bxclub.co.uk/forum/viewtopic ... 15&t=10164
electrokid
I changed all my dash bulbs several years ago - that was a one-off job - no problems. IIRC you'll need about 32 of them - you should be able to buy the bare bulbs - ie: without the plastic holder bit in boxes of 10 on eBay or from a decent parts shop. And at these prices...
http://www.ebay.co.uk/itm/10-X-286-INDI ... 19f4928a5f
(I think those are the right ones - they are definitely 1.2W)
IMHO not worth bothering with LEDs !
2002 C5 HDi SX estate
