Cross Reference for rad and oil breather hoses
Slagtrooper
Post by Slagtrooper »
Hi,
Tried to look for new hoses with its codes and i couldn't find similar ones. Read some topics here that says its already difficult to find for some engines.
The radiator hoses are compatible with other engines like some XU10's? Even modern engines, from other makes, etc. Same for the Oil breather's.
The main idea is using OEM, plug and play parts. Always good (or bad?) to remember that i'm in Brazil, so X-Ref is always a good choice...
Citroën BX GTi 1993
. XU9JAZ engine, ZF 4HP14 Automatic gearbox
. Leather Seats, Air Conditioner, electric mirrors, windows and sunroof
. "16V type" Speedline Rims, "Ducktail" spoiler and rear vents
ORGA 5219 (February 22, 1991) - Made in Uruguay
Hot steamy night alone, I wait for you ? Cold brittle morning alone and I cry for you ? And when you finally call ? You cloak your moves in the shadows ???
x 103
Re: Cross Reference for rad and oil breather hoses
I imagine a fair number of these would fit your car.
Certainly anything close to the engine should be okay, the main differences will be hoses that connect with the radiator.
http://www.spoox.co.uk/en/253-coolant-hoses
BXImage
Post by BXImage »
Ref. No for oil breather hose (that goes from filler neck to the sump) is 1180.45, fits both 1.6 and 1.9 engines. Same for Peugeot 205/309/405.
