I am looking for a door lock set and keys for my recently acquired '94 1.9d estate, ideally both front doors, fuel cap and glovebox, could manage without ignition barrel if necessary.
Could collect from nec sunday 16th nov.
Car has central locking, only drivers door lock not working, going to strip it once car in garage when I clear enough space!
Thanks
Tim
Wanted-lock set
kernowtim
- My Cars: BX 19 estate
1999 ford focus 1.8TD
classic2cv
Re: Wanted-lock set
I think that i might have an ignition barrel / steering look in my shed
Citroen BX
Origami in plastic and steel
^^bx>
Re: Wanted-lock set
I have a pair of door locks and a glovebox (grey) all on the same key, no ign or fuel cap tho, might have 2 keys, let me know if you need them.
kernowtim
Re: Wanted-lock set
Hopefully sorted now, thanks for the help and offers. On to the next problem(s) .. cracked and breaking up tailgate !!
Re: Wanted-lock set
New tailgate should do the trick, sure someone on here will have one. I had this around a o/s hinge but the n/s seemed perfect, can only guess the tailgate had been twisted at some point and small crack spread after several more slams and eventually broke away around the pin.
themildbunch
Re: Wanted-lock set
The bolts that hold the lock to the tailgate gradually work loose over time and repeated slamming will crack the plastic they're mounted too.... I had to fill mine with epoxy to get the lock mechanism fixed securrely.. been fine for several years but I try to shut the boot carefully - it's pretty heavy.
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
