Or, big pile of black spaghetti!
http://www.leboncoin.fr/equipement_auto ... htm?ca=4_s
Home made octopus replacement system....
- Thread Bear
Re: Home made octopus replacement system....
Hmm. This does not resolve the fundamental problem. Reducing the amount of soft, degrading rubber, thus increasing solid, non degrading pipe work. Where there is a need for a rubber pipe to get it into a position where it is simple to fix. Then pack several repair sections of rubber pipe and Bob's your Aunt Lucy and you should never have another low pressure or return LHM leak that causes a fail on the road. Very little else goes wrong on the oiler version, so it brings the reliability into the top rank.
- Slagtrooper
Saw that kit in some Yaronet's BX World topics, wonder how that manifold block was made...
It's interesting for sure, think about an all modular system...
Citroën BX GTi 1993
. XU9JAZ engine, ZF 4HP14 Automatic gearbox
. Leather Seats, Air Conditioner, electric mirrors, windows and sunroof
. "16V type" Speedline Rims, "Ducktail" spoiler and rear vents
ORGA 5219 (February 22, 1991) - Made in Uruguay
Hot steamy night alone, I wait for you ? Cold brittle morning alone and I cry for you ? And when you finally call ? You cloak your moves in the shadows ???
At the moment, its far easier to just go buy a new Octopus from Citroen and fit it.
- Vanny
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 82
While I understand the benefits of the brazed manifold (possibly in copper?) I dont understand why anyone would use rubber in this day and age, especially diesel leak back pipe as pictured.
Much of my low pressure return system has already been replaced with silicon pipe which gives far better UV/Oil/Temperature resistance than rubber. It also means i no longer need to buy strut return pipes every 4 years!
