Hi all.
My good mate Charlie Vacy Ash has a 17TD estate with 180000 miles under its wheels.
It's run fine for the last 4 years but has developed a bad fault in the last week and we wondered if any of you good forum folk could help...
We're pretty sure that it is not running on all cylinders as it's running very rough with white smoke from the exhaust. The injecters have been tested by a local firm and are fine.
Any ideas???????
Rich
17TD Rough running
17TD Rough running
'86 2CV Dolly
'81 2CV 007 Drummer
'82 HY Shorty
'77 Smurf blue Ami8
'81 2CV 007 Drummer
'82 HY Shorty
'77 Smurf blue Ami8
Re: 17TD Rough running
How about air getting into the fuel system. That would make it run rough.
Head gasket, water getting into one of the cylinders hence the white smoke and not running on all cylinders, is it using any water?
- Stinkwheel
Im with Andy as I mention on text Rich. I think its air getting into the fuel system.
Assuming Chas did the brake valve, has something nicked or levered against anything that may be allowing a bity of air in the fuel line?
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
- Stinkwheel
Having said that, the headgasket thing might be true also, I seem to remember that his car has been using a little water very gently over the last few years hasn't it?
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
