14RE lower water pump hose?
speedingfine
Post by speedingfine »
Anyone got a part number? I thought the car had properly expired, was very pleased to find it's just a split hose :)
Pics to follow if I've not been clear...
Re: 14RE lower water pump hose?
if you send me the last 8 digits of your chassis/VIN No. i will check if service citroen will oblige with your car specific parts and numbers
speedingfine
Hi Malcolm, thanks. It's 02ER9442
nop that didnt work try the full VIN,
citroen are deleting data for some of the older cars, so it seems the last 8 do not always come back with your car specific info, sometimes it requires the full VIN to wake up/dust off this older data
and is this the main bottom hose your after
Stinkwheel
Post by Stinkwheel »
One question, is it a 150 slant back suitcase engine or an Upright TU. Both were sold in the 14RE flavour BX. I think the hoses will be very different.
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
speedingfine
Hiya it is the suitcase engine and it's the long hose from the front right of the engine that goes right round the back of the block.
Thanks for the help.
so its the bottom rad hose then, if so this should be the OE part No.
suitcase engine
95 566 627
NFP
RADIATOR WATER INLET HOSE
DIAM INT 32
