bx 16v top matrics heater hose
greendale65
Post by greendale65 »
Hello all, Ok I'm not going to get the hose I need
has anyone tried a different way to over come this
problem , Don't even know what shape the hose is
or size any help on this.
^^bx> 16valver
Re: bx 16v top matrics heater hose
If you have the car surely you can measure it? :?
It would certainly be easier than someone trying to describe the shape of a hose on a forum!
You could make up the hose with lengths of universal heater hose, and elbows like these:
http://www.carbuildersolutions.com/uk/h ... and-elbows
Or even plumbing fittings, wouldn't look 'factory' but would be functionally OK.
Post by Mothman »
Why cant you get the old one copied? Do you have the old one?
x 103
What price do you want to pay as this is clearly the priority. We've already identified a supplier of hoses for you, but you seem reluctant to use this supply, I presume on cost grounds?
Have you looked at your private messages for any other suggestions? I've sent you two messages but had no response, perhaps you are not aware of the message system.
Andy, in my experience getting a single hose copied is quite expensive, around £100 per hose up to about 1 foot long. By the time you've got these two hoses copied, you could have bought a full 16v set
Post by Mothman »
Ah, didnt know that it was that expensive, a good note for the future in case i need one for my GSA.
Ta bud.
greendale65
Vanny wrote:What price do you want to pay as this is clearly the priority. We've already identified a supplier of hoses for you, but you seem reluctant to use this supply, I presume on cost grounds?
