Hydraulic pump problem?
kieran.l
- x 3
Should the HP turn free and smoothly by hand, without any notching or stepped feeling? Pump is on a 1.6 petrol. My uncle thinks he let it run dry and isn't sure if something is wrong with it now. Thanks
Kieran
1984 BX 19RD
2018 Peugeot 3008 1.5 BlueHDi EAT8
1984 BX 19RD
Re: Hydraulic pump problem?
it should be easy to rotate with no hydraulic pressure pumped up, and you should feel as the internal rotor presses each pistion in turn
