Hello all, Anyone got a good one.
16v
BX 16V SPEEDO CABLE WANTED
Re: BX 16V SPEEDO CABLE WANTED
Safe to say no afraid not
1991 Citroen BX 16v - Red
1991 Citroen BX 16v - Silver
1992 Citroen BX 16v - White
Scrapped:
G650PGX 1989 ph.2 red BX 16v
G-VOT 1989 ph.1 White BX 16v
Scrapped:
- Tim Leech
- x 150
If it's a top one they are the same as most other mk2 'a.
have a look at this ebay item
331430699069
331430699069
At 485mm long, I'm not sure it would fit my 16, with BE3 gearbox at all. Too short for an upper and too long for a lower, so measure your cable lengths first. Looks to me like an upper for a LHD version but I stand to be corrected.
it is the lower section, if you look at the first picky you can see the fitting that goes in the gear box,Tinkley wrote:At 485mm long, I'm not sure it would fit my 16, with BE3 gearbox at all. Too short for an upper and too long for a lower, so measure your cable lengths first. Looks to me like an upper for a LHD version but I stand to be corrected.
here is what service citroen show for the BX,
only one part No./length through all the below models
96 073 325
LONG 485
1,580L AND PETROL
LONG 485
1,905L AND PETROL
LONG 485
1,769L AND DIESEL FUEL
LONG 485
1,905L AND DIESEL FUEL
LONG 485
1,905L AND PETROL AND BORD COMPUTER
LONG 485
1 360L SINCE RPO 04253 UNTIL RPO 04724
LONG 485
and below are the other part No.'s and lengths showing
6123 A4
NFP
LONG 222
INJECTION AND 4X4 AND 1,905L
LONG 222
PETROL AND 4X4 AND 1,905L
LONG 222
4X4 AND GTI 16S
LONG 222
DIESEL FUEL AND 4X4
95 496 555
NFP
LONG 570
GTI 16S
LONG 570
1,905L AND PETROL EXCEPT BORD COMPUTER
6123 G9
NFP
LONG 330
SINCE RPO 04725
ps,
and the one on ebay is still showing as available from citroen, and cheaper than the ebay listing
96073325 SPEEDOMET CABLE 23.53 GBP 28.24 GBP 28.24 GBP
also this upper section is showing as still available
95638113 SPEEDOMET CABLE 26.02 GBP 31.22 GBP 31.22 GBP
but it does not state which model it is for
Now you know one reason I'm not too fond of LMC.....citronut wrote:ps,
Thanks for recognising the 'lower' though. I changed my upper a few years back but the lower is quite old and I'm not sure the 'tang' on the lower at the joint is as good as it should be. Lot of variable waving about circa 40 -55mph, at times.
- greendale65
- x 20
Ok, Thanks allTinkley wrote:Now you know one reason I'm not too fond of LMC.....citronut wrote:ps,
- greendale65
- x 20
Ok, Thanks all.citronut wrote:ps,
