Due to impending loss of garage and off road parking, it is very likely I will need to sell my project bx estate, which is Red L reg 1.9 diesel, manual transmission. 231k miles, mot may 5th 2015,advisory on front reg plate (replaced) and corroded fuel pipe.drives fine,suspension works as it should, PAS and towbar fitted
Currently Sorned, recon rh driveshaft and lower eng mount being fitted.new parts fitted recently include belts and water pump.recent service and filters.steel wheels with cheapo trims and good tread on tyres.front pads will need changing at some time, interior good but dash has fixing holes from cb radio, clock doesn't work,instrument panel and tray loose.body seems OK,drivers door hinges good , worst is rust around left tailgate hinge and rear wing.Various dents and peeling lacquer.front lh window sealed shut, no radio, Tailgate cracked.no parcel shelf
can't think of anything else , just killed phone and can not transfer photos from camera to tablet computer, so no photos at moment.
any questions please ask!!
Would like £600.00 but open to offers!!
1994 BX 1.9 TXD estate, needs new home!! located in Cornwall
kernowtim
- My Cars: BX 19 estate
1999 ford focus 1.8TD
kernowtim
Re: 1994 BX 1.9 TXD estate, needs new home!! located in Corn
May rent garage so I can keep car, dont want to scrap it!!
Will cost £51 per month though
I don't know what your insurance costs but putting a ticket & tax on the car will cost you less than half your garage outlay for a year. Then you can keep it on the road and move it about to work on, plus have normal use of the car while its roadworthy.
