It has been a while since I visited this forum.
Today my car lost power, first I notice the radio has turned off the lights got weaker and the dash board illumination has been weak for a few days already.
I kept driving but it was getting difficult as there were definitely not enough sparks to run the engine properly. I made it home but I won't drive it withouth fixing first.
Does this sound like the alternator.? The battery is good as it is less than a year old.
If this is the alternator, how easy is it to fix on the road.
... a black cat did cross my way this morning and also my 2y old dropped my phone into a bowl of water. no phone, no car
alternator ?
cacaolat
alternator ?
Tinkley
- x 8
Re: alternator ?
Firstly I'd charge the battery! If you have a multimeter you could check the voltage after charging, anything somewhere towards 14v or up should be good. If you have a battery that allows cell top up with distilled, remove the caps and check the water levels. It only takes one bad cell to be a problem.
The alternator is most likely the culprit, probably dirt around the brushes or they are worn out. One rather crude 'fix' is to hit it with a sharp blow with a large hammer!. This dislodges the dirt around the brushes and will allow it to run a bit better. It is however only a temporary fix and how long it lasts is an unknown. A few years back I got an exchange alternator for £50 and the replacement was a genuine Valeo one. Look on the 'bay and also phone a few decent factors, they might have one sitting around. Worth a try on some of the alternator exchange specialists too. There was an 80 amp (6 V belt) one on the ' bay recently, I think you need the 50 amp one with the 4 V belt end spindle flange.
Replacement itself is dead easy, but disconnect the battery first and check the small lead mount position. There was an extra lead mount stud on my replacement unit, which has remained unused - some other model of BX or Pug must use it.
Re: alternator ?
i would be very cautious of hitting an alternator to jar the brush's, as might help with doing the same to a starter mopter,Tinkley wrote: One rather crude 'fix' is to hit it with a sharp blow with a large hammer!.
as the alternator casing/body is nowhere near as strong/tough as a starter motors is, you risk cracking the casing,
far better if you think the brush's are just stuck/sticking with carbon dust is, remove the regulator from the alternator
( fairly easy insitue on some engine variety's ) ,
then give them a good blast up into the brush holders with the likes of electrical contact cleaner, or carb/brake cleaner/compressed air,
now check if the brush's firstly have a reasonable length protruding, and if they spring back out after being pushed into there holders,
if hardly and brush protruding you will either need to fit new brush's of source a complete regulator
Re: alternator ?
Keep the Multi-meter on across the battery terminals whilst the engine is running to find out if the alternator is charging, you need a minimum 14.5v for a good charge.
Tinkley
- x 8
Re: alternator ?
Well it (large lump hammer) was a technique demostrated by a roadside rescue tech - and it worked!. Looked brutal and not something I would naturally have done for the reasons you outline. Still that alternator went for exchange....citronut wrote:i would be very cautious of hitting an alternator to jar the brush's, as might help with doing the same to a starter mopter,Tinkley wrote: One rather crude 'fix' is to hit it with a sharp blow with a large hammer!.
Did not look too easy to do the brushes on the alternator, the starter motor I have done, all £1.60 of brushes.
Re: alternator ?
I bashed the TXD's alternator for a few years, it was fine.
cacaolat
Re: alternator ?
I have a busy time with house renovation, school runs and work so I found a mobile mechanic who fixed a newly refurbished alternator on the same day. All fine now
Tinkley
- x 8
Re: alternator ?
Good to know you got it sorted. Well diagnosed too, you will appreciate the better fuel economy as well...
Re: alternator ?
I always keep a spare one handy after having had 2 fail on long journeys to Cornwall. I get them locally reconditioned so that i know it will work rather than relying on those from ebay which ive had go wrong in a couple of hours after fitting.
Re: alternator ?
Tinkley wrote: you will appreciate the better fuel economy as well...
KevR
Re: alternator ?
Same with the grey TZD's - a smart tap on the end of a bit of wood held on the casing, ideally with the engine running. Managed to put off replacing it for at least a couple of years after it first started playing up. Eventually the slip rings and/or brushes will wear out completely though. If you're handy with a soldering iron, replacement brushes, slip rings and bearings are cheap enough. I've got several alternators waiting for rebuilding, and I think the parts cost about a tenner per alternator.MULLEY wrote:I bashed the TXD's alternator for a few years, it was fine.
Tinkley
- x 8
Re: alternator ?
When the alternator does start to 'go' the output is not good enough for a healthy spark on the ignition circuit. I believe the OP's car is a petrol as per the comment 'not enough sparks to run my engine'. When mine started playing up, one of the signs was poor fuel consumption...Defender110 wrote:Tinkley wrote: you will appreciate the better fuel economy as well...
Rather assumed a diesel won't need the sparks as long as it turns over OK!.
Re: alternator ?
Ive run a diesel from Cornwall twice with a completely buggered alternator. None of the elecrics would work, hand signals only and she got me home all the way. Just was careful not to stall her.
