BX Diesel Manual Box needed
themildbunch
Planning for a possible project in the Spring to convert my 1.9D auto in to a manual but need the right box, either that or an engine / box together...
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
Re: BX Diesel Manual Box needed
got the linkages, pedal box and all that stuff, but not a NA box...
Ask Barry at Bourne citroen Or rob at Chevronics?
- x 60
I have got a 1.7D (NA) manual gearbox lying around.
I don't have a flywheel to go with it though.
Its had new input bearings in it, you can have it for the cost of the bearings, if you collected it.
You will also need flywheel bolts as they are longer than auto ones, also the small ball headed stud thats fits into the top of steering rack forms part of the gear linkage, bypass the gearbox lockout solenoid, rest is fairly straightforward.
