Indicator stalk wanted
RobC
My Cars: 1991 Citroen BX 16v
x 30
Post by RobC »
Anyone got one? My main beam has failed and the one I bought to replace it was also bust!! Not amused...
1991 Citroen BX 16v
Re: Indicator stalk wanted
I am sure I do, at my lock up, will be the weekend before I can get there though Rob.
and if young timmy cant find one i should have a few
RobC
x 30
Post by RobC »
Thanks both that's very kind.
Just want to double check: if the full beam flashes when the lights are off, but doesn't latch onto full beam when the headlights are on, is that a fault with the switch,
Not something else like a fuse?
1991 Citroen BX 16v
Sounds like the switch, had one go like that on me before.
does main beam come up if you hold the stalk in the main beam position,,
if so it could be a relay not triggering
if you fancy you could always give your car a blat down the A21 to St Leonards on sea were my workshop is,
RobC
x 30
Post by RobC »
Hi Malcolm
Yes the main beam 'flasher' works fine with the headlights off.
But if you hold the stalk in the main beam position with the headlights on, then nothing. No latching and no full beam.
1991 Citroen BX 16v
RobC
x 30
Post by RobC »
I have found brand new Valeo ones for £30.
If anyone would like to half that with a second hand one then get in touch.
1991 Citroen BX 16v
sorry for delay in replying Rob
pm. sent
CitroenBaz
Post by CitroenBaz »
hi all, just thought i would ad this on hear i have just bought 4 new valeo units from one of my suppliers, the last 4 he had.i thought i would put them on hear first at £ 35 each, then on ebay , barry at bourne. PS , just found a supply of front bumpers, not cheap £180 2-3 week delivery.
RobC
x 30
Post by RobC »
With the 33% Monday discount from GSF I just splashed out and bought a brand new one for £20.
Thanks to all for the offers of help though.
1991 Citroen BX 16v
