I changed all of the spheres to brand new comfort ones (I've got to change the accumulator one though). Oh and I had to make up some new copper fuel lines as the original steel ones were shot.
After all of this, just last night we were ready to fire her up, I was sceptical as to whether it would run as the battery hasn't been used in two years, however, she ran! After about 8 goes she fired up, unfortunately there was no lift in the suspension... we checked the haynes manual, tried out a few things, including undoing the pressure valve slightly, also undoing the the output pipe from the hydraulic pump after priming it to check it was actually working, which it was.
After all of this, it still wasn't working, so I suggested we left it running for a bit and come back to it, and as we turned to leave the shed we saw the front of the car lift! She raised herself up right up to the high position for the first time in 14 years! I still can't believe it's working!
So, after what seemed like an unending list of jobs to do (which I was quoted £1200 just to do the suspension pipes by a citroen specialist...) I've finally had some reward, sure there's still things to do - when I pressed the brake pedal a green spurt of LHM shot across the shed floor... and the brake pads and discs need changing, but they're minor compared to the suspension pipes. All in all I'm delighted - I'll post some proper pictures and videos later in the light, I'll try to add a link to the video I made last night shortly, although it's quite dark.
Just a quick question, what's the best way of removing the accumulator sphere? I tried today with a chain wrench but failed...
