Cooling system bleed screw needed urgent
x 138
Post by rutter123 »
Managed to snap the top off mine now its pissing coolant, this is the small plastic bleed screw located on t/stat housing, anyone got one? For a gti 8v
demag
Re: Cooling system bleed screw needed urgent
Post by demag »
I haven't got one but isn't this a standard metric thread? Possibly 5 or 6mm in which case a short hex head bolt might get you out of trouble for now.
Dave.
1990 Bx TGS automatic.
demag
Post by demag »
Dave.
x 138
Post by rutter123 »
Spotted the above myself, mine is plastic with a small o ring, but for a few quid gotta be worth a punt, just a case of getting the broken bit out.
Tinkley
Post by Tinkley »
I won't use this bleed screw, as it is a part that becomes brittle and breaks. So now I just leave in place and use the radiator upper bleed screw instead. Seems to work OK if you top and repeat after running a bit, certainly not noticed anywhere not getting filled correctly. Probably a heat cycling thing on the polymer and with such a fine thread, I'd be a bit concerned about stripping the thread on the thermostat housing, a more difficult thing to fix! I'm assumming it's like the black plastic version on my 1.6s'... most likely Nylon 66 btw.
rutter123 wrote:Spotted the above myself, mine is plastic with a small o ring, but for a few quid gotta be worth a punt, just a case of getting the broken bit out.
what when citroen are asking this for it and its sealing washer
130629 DRAIN SCREW 1.07 GBP 1.28 GBP 1.28 GBP
824918 SEAL WASHER 0.63 GBP 0.76 GBP 0.76 GBP
L*o*u*t*h obviously aint done there home work then!!!!!
