Morning all.
Couple of quick questions. Got the whole front end in bits on the white one, have welded up the inner wings etc, and it'll be going back together with new wishbones, struts, doseur, bearings, balljoints, rad, hoses, calipers, discs etc. While I'm at it, and since it's been stood a while (7 years) I'm planning to refurb the height corrector and change the octopus.
Anyone got a good source for a rebuild kit for the HC? Or is it just a case of strip, clean and rebuild?
And as for the octopus, I've just remembered I bought the one I've got on the shelf over here in France, but I don't know if there's a difference between LHD and RHD versions.... anyone know, or can give me a part number for the octopus and the small octopus for a RHD 1991 TZD estate....? I've had a look on Cit Service but it's not very clear (or at least, it's not to me!).
Ta in advance,
Kev
Height corrector and Octopus
KevR
themildbunch
Re: Height corrector and Octopus
you can get a repair kit from Citroen Classics...
I had my front one rebuilt after it got damaged removing the engine and started to leak..
Isn't everything in the same place apart from the steering column / pedals on the LHD models? I'm sure they'd have saved as much money as possible and tried to not make too many differing parts!
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
KevR
Ta for that. Yes, I think everything's in the same place, but I never take common sense for granted when I'm dealing with Citroens!
look under "braking" then "pipes" then "return piping" and its No. 2
96030258 OIL BACK HARNES 50.21 GBP 60.25 GBP 60.25 GBP
and still available from cxitroen
KevR
Thanks Malcolm - might have to buy one. Can't find the one I thought I had to check if it's right or not!
But the two small Octopii I've got are definitely the wrong ones. They've each got two small pipes coming out of the union on top of the LHM tank, and the ones on my cars have three...
As for HC rebuild kits, keep looking on Leboncoin, they seem to crop up quite often.
KevR
Really? I've never seen one on there! Although I did miss a bbrand new HP pump for 50 euros this week, which I'm gutted about....
Tinkley
- x 8
The Squids (little octopii) are different depending on build number - the Parts list gives the exact No, so your 'wrong ones' will fit, just an older model I believe.
KevR
Yes, I think the ones I've got are for diesels up to build number 05167.
I've got two available if anyone wants one!
here are part No.'s for what i believe commonly known as the squid/small octapussy, were the main block/body is at the hydraulic tank
"EXCEPT POWER STEERING"
95 567 454
HYDRAULIC OIL BACK HARNESS
LONG 935
- 1 360L UNTIL RPO 04192
96 046 578
- 1 360L SINCE RPO 04193
95 638 836
RUBBER - C001-
- PETROL AND 1,905L UNTIL RPO 03685
+ 96 004 951 (01) + 96 004 934 (01)
RUBBER - C001-
- PETROL AND 1,580L UNTIL RPO 03685
RUBBER - C001-
- DIESEL FUEL UNTIL RPO 03685
RUBBER - C001-
-PETROL AND DIESEL FUEL SINCE RPO 03686 EXCEPT 1 360L
"POWER STEERING SINCE RPO 05168 EXCEPT 4X4"
96 119 048
96 085 660
NFP
and here is price and part No. of the one of the above two that are still showing as available from Citroen
96119048 OIL BACK HARNES 62.45 GBP 74.94 GBP 74.94 GBP
and
"POWER STEERING AND 4X4"
95603421 OIL BACK HARNES 65.65 GBP 78.78 GBP 78.78 GBP
"POWER STEERING UNTIL RPO 05167 EXCEPT 4X4"
95 603 421
- PETROL
95 603 420
- DIESEL FUEL
95603420 OIL BACK HARNES 65.65 GBP 78.78 GBP 78.78 GBP
95 567 454
LONG 935
96 046 578
95 638 836
RUBBER - C001-
RUBBER - C001-
RUBBER - C001-
RUBBER - C001-
96 119 048
96 085 660
NFP
and
95 603 421
- PETROL
95 603 420
- DIESEL FUEL
KevR
That's the one (or the two) that I've got. 25 quid each posted if anyone's interested!citronut wrote:
95 603 420
- DIESEL FUEL
Kev can you ignore my pm. i just sent you requesting one of your small octapussy's as i just re/read above were you state the two you have have only got two small pipes coming from the main block, like your mine being a TZD also has three small pipes
tWo part No.'s for THE version with three pipes are
96 119 048
NFP
96 085 660
all the other models/part No.'s only show two small pipes
regards maqlcolm
96 119 048
NFP
96 085 660
regards maqlcolm
