Clock not working..
Retrofrench
My Cars: 1993 BX TZD estate
C15 D
Former Citroens
1988 BX 16TRS in white
1988 BX 16TRS in red
1990 2CV6 Special
Clock not working..
Post by Retrofrench »
I have a clock next to my speedo instead of a Rev counter. The clock doesn't appear to work? I would assume it gets its power from the battery unless it has an internal battery? Any ideas? And the speedo needle appears to have severe Parkinson's, I recall the exact same thing on my Renault 5 - curable or just a quirky french thing?!
Oops - posted in the wrong place, not sure if I can move it?!
macplaxton
Re: Clock not working..
Post by macplaxton »
Change the speedo cable for wavy needle.
Clock should just work off the battery. Change it or work out what is blown?
Retrofrench
C15 D
Former Citroens
1990 2CV6 Special
Thanks for that. I'll try and get a new speedo cable. The clock is part of the speedo cluster so it can't be easily changed? I'll check all the fuses today after I've serviced the car.
x 138
Post by rutter123 »
I have a good working clock if u need, its still in the cluster.
